340 with odd numbers
pauly v.100
honolulu, hi.
1970 build date
the # stamped on the pan rail is IEI 856
Is this a warranty block? if not, than what?
probably a 1971 model year engine out of an LA built car
revised block id #GW340P33810351
I didn't realize there were numbers on the upper deck area, probably a byproduct of my ignorance and poor eyesight!
thanks Rocky and MrMopartech for the heads up.
I'll post a separate thread now that there's no mystery to this block.
one question though, aren't the pan rail numbers and the upper deck numbers supposed to be the same?
thanks again, -pauly
Nope
The pan rail is the vin for the car it's out of, 1exxxxxx 1= 1971 E = Los Angeles
The front of block is year, plant, size, fuel assembly date and days unit number
G = 1971
W = Windsor plant
340
P premium fuel
3381 = Oct 30, 1970 Build date
0351 = 351st built that day
