1969 disc and drum lower ball joints
ir3333
ontario,canada
I have read that '69 disc brake lower ball joint on A bodies is the same as drum brake lower ball joint but uses 9/16" bolts instead of 1/2"
..has anyone just drilled the drum brake ball joints to 9/16 or is the disc unit cast a little thicker in this area for the larger bolt hole?
Same casting. Drill the ball joints out to 9/16" and they work just fine.
