Due to there size alone grade 5 is more than enough. I did a 6800 rpm side step the clutch launch, IN REVERSE! Spit the transmission out but the four ears were still bolted to the scatter shield!
i agree the cost difference is so little why would you use grade 5 but then again if your sitting on a street corner with a tin cup maybe grade 5 is all you have the money for
