[SOLD] A-Body Console
R4Sedan
Larry
Weeki Wachee, Fl
I have For Sale a complete set-up A-body console consisting of shifter,brackets,rods,clips,bolts,wiring,etc....Please look at the pictures I believe everything is here if you are swapping over to a Automatic console or if you don't have one. I tried to find all the bolts,clips,screws,so you wouldn't have to go hunting around. It comes with both early and later shift balls. The later one is just missing the button. I couldn't find it. The console needs a little work, but nothing bad. I would like $300 for the whole lot. plus the ride.
Spring Hill, Fl 34608
PayPal,Check,M/O.
Thanks, Larry
If you were willing to separate as gniknayrb18 asks above, what would you want for the console?
Thanks,
Richard
Hi Larry, can you tell me what looks like a switch module and harness connected to the shifter is for... I just remove mine shifter assembly from the car and I didn't see that in mine.
Thanks
AlV
Thanks
AlV
That's a reverse light switch. The later A-Body cars have that switch on the tranny instead....
If console is still available I am in need of one. Please let me know pricing . Will send pm as well.
Thanks
Rodney
