[WANTED] piece for 1 bbl carter carb early style 60-66
VDART
Shulte Ks
anyone have any early rod linkage style carter carbs for parts--- I need the pivot screw with the should for my slant carb-- please look at photo-- you will see the prior owners fix.
thanks Lawrence
i might have one but its gonna be a whole carb... my question is if it works and isn't going to fail whats the issue?
to answer you question -- I have not tried the carb out yet-- I noticed the piece missing -- this causes a lot of play in that arm which is the accelerator pump. probably not a good thing--
just a simple screw-- if I cannot find one then I'll move on.
here's my question to you
do you cobble up your car when you can get a cheap correct part 805moparkid?
Lawrence
Lawrence
i didn't know it was wobbly. and cheap and correct never seem to come together for me lol... as i said pretty sure i have a whole carb in the garage if your interested
