[WANTED] '71 Dodge Dart parts needed.
Propwash
FBBO Cat
The Muppet Show
He guys...Looking for some A-Body stuff. I need:
Front turn signal pigtails for '70-71 Dart (unsure if any other years work)***No longer needed, found***
Forward light harness for '70-71 Dart ***No longer needed, found***
Small block motor mount brackets for '71 Dart (340 motor-)
8 3/4" lower shock mounts ***No longer needed, found***
Thanks for the ad FABO
I've got those pigtails and they have the chrome lights attached, $30+frt from Mich. Came off 71 Demon
I looked for your location. I don't see one.
Location is Wisconsin Oldman
Hey Paul, I was looking for the front turn signal pigtails (in the grill), but those side marker lights you have are are pretty sharp. If I didn't have a set already, i'd be taking them off your hands.
Update:
No longer in need of.........Turn signal pigtails or the forward light harness.
I have the lower shock mounts for the 8 3/4 PM me if you still need them. BTW your cable shipped out today
Thanks again
Don
Thanks again
Don
Hey thanks Don. Sent you a PM at your other store
I may have Front turn signal pigtails for '70-71 Dart*will check in the morning
Thanks demon. I was able to buy a set earlier today. Thank you for posting though.
Hey Will, Welcome to the A body side !! Check out the Gang Green 68 GTS
i have a set of mounts in the shop somewhere
I'll see if I can find them tomorrow
Those are the rare ones but I'm pretty sure thats what I have
I'm in need of a fan shroud 2998325, or $ is always good
