Porting Kits
Bad Sport
HALF A BUBBLE OFF
Staff member
Legendary Member
The Wolverine State
What's everybody using for home porting kits.
Likes, dislikes, PRICE!
I would like one that has the short and long mandrels but haven't found one yet. This will be for mild porting just to smooth things out a bit!
Anybody know of one?
And buy a good carbide cutter or two , makes the early stages go faster.
Steel and aluminum take different cutters too
Yeah, I have a few cutters, but will probably get some longer ones.
I don't want to get overzealous as this is 1) a mild build and 2) I haven't the experience yet.
Gotta start somewhere though.
Snap-On has 5 long burrs in iron or alloy types.....if that helps any.
I get my supplys from Falcon Tool out of Dayton Ohio. Google them to get their number. They have it ALL. carbide cutters, short and long shanks, Double cut for steel/iron and cutters for Aluminum. Mandrels for cartridge rolls. They sell cartridge rolls by the 100 lot. About $36. per 100,..good deal. You will need 60 grit and 120 grit that will cover everything you will need to do on any head or manifold. 1 inch long and 1/2 in diameter. No need for tapered rolls...you will have one after 5 minutes, a total waste of money to get those, IMHO. You will need a 6 inch and 4 inch long mandrels, a 2 inch you will use sometimes on close up (chambers) work. You will need mandrels with a 1/8 inch pilot hole and 1/4 inch shank, they are cheap so get extras,..spares are good to have. Check them out a good company to deal with. Been getting my stuff from them 25 years.
Terry
Summit has long cutter sets and a sand paper kit with arbors.
I ended up with the kit from Summit, they did have a longer mandrel which I added and I got a 3 cutter kit. Total cost was was about 85 bucks.
