Are all TQ phenolic(black) spacers the same??
4spdragtop
Ontario Parts Unknown
When I rebuilt my 84 TQ, I noticed what a couple of hairline cracks where the mount bolts goes thru from the top airhorn. I took it apart after some flooding issues, to give it another cleanout. There was fuel in the bottom plate, directly below where the wells are located on the phenolic spacer. I have some carbs at home, plus Oldkimmer has some TQ's as well. I dont wanna tear it apart and be left waiting as this is my DD. Its a truck TQ 9379S for an 84 360. Will any TQ spacer work??
Thanks all
there are differences between them, obviously 800 to 850cfm. just have to eyeball them closely. i have used this seal all to glue the wells and it hold you could try it on the cracks if they are minor [ame="http://www.ebay.com/itm/like/170724345216?lpid=82"]3 Lot 2 oz Seal All Purpose Adhesive Sealant Glue 380112 Fast Drying Clear New | eBay[/ame]
Thanks for the link EL5, not sure if mine is an 800 or 850, I do know its a 9379S, so will investigate. Thanks again!
should be a 800 cfm with the 1 3/8" primary
9379= 83 360 Truck BV F (4287016) 1-3/8
If you're not in a hurry, I am sure I have a body I can send you.
