straightlinespeed
Sometimes I pretend to be normal
Guys, Im trying to figure out my front suspension.
I have a 71 Scamp, that at some point was switched over to the LBP and discs. I have a little bit of everything on my front suspension and steering. By this I mean..
I have 71 steering components, inner/outer tie rods and center link as well as idler and pitman arms.
Now where Im confused is what suspension components Im running. Im trying to figure out what LCA's and UCA's I have. Is there a way to easily identify these, being that I dont have sway bar tabs.
I have a set of 72 down LCA's with sway bar tabs that Im wanting to use but not sure if I can use these with the LBP discs. If I cant I will search for 73 and up LCA's. The reason Im digging into this is I want to gather parts for this winter to rebuild my suspension, and want to make sure I order the correct stuff.
