Friend had an older industrial tractor,develop a hairline engine block crack .He did a small root v channel with a grinder, slap JB Weld in the root channel.Worked like a charm.
Using starting fluid and a match to seat the bead on a tire. I've only done this on motorcycle tires but it would also work on a car tire.
I have never done this...but I have used ratchet straps. See,s like every time I need to use the handtruck, or the pressure washer it has a flat. Wrap the tie down around it and crank it down.
Seeing Jacks madman jump start with the jack reminded me of when I saw a guy on the side of the road with a scooter, dead battery. Pulled up in front of him with the truck. He went to hook up the cables with my diesel still running. Can't help but wonder how bad it would have smoked that little battery if he hooked it up to my truck with the 130 amp alternator charging...
There's two things that have to been done for this to be remotely safe (it ain't safe, but it can be done w/o risking life and limb).Some idiot doing that on a car damn near killed my old boss!Using starting fluid and a match to seat the bead on a tire. I've only done this on motorcycle tires but it would also work on a car tire.
A long time ago a buddy and myself were crusing around one night in the rai and the wipers quit.
I took my shoe laces out and tied one to each wiper and ran them into each side wing window. (one for me, and one for him)
Kind of a seasaw type action all the way home on the freeway for 15 miles.
Ok, you got me. What's a pickemup?
That is a good stiff drink when you need one.... LOL!
If you are in need of a boost or know somebody that needs a boost and there are no booster cables around. Touch your chrome bumpers together and use the bumper Jack from one positive battery post to the positive post in the other car and start the car.
Jack
No, that's a pickmeup, a pickemup is a pickup truck.
tomato, tomahto.... :???:
First is PULL the valve stem core before ignition!
Second is, after squirting some fluid into the tire keep squirting and lay a trail of fluid on the ground to about 20 feet away. Light from the end of that trail, not at the tire!
Is that peekup mine???? No? Then it must be urine!tomato, tomahto.... :???:
Wouldn't have hurt it...I once jumped a little motorcycle off a truck with a 200A alternator. Yes, it fired right up.
I've also heard of using egg whites to stop radiator leaks.
