longer wheel studs
Those are direct bolt lugs meaning the mounting surface to the nut is machined flat. They are required for a direct bolt rims. I'm not aware if all welds are a direct bolt wheel. You need to have the correct type.
Cronical through bolt lug-----> http://www.summitracing.com/parts/rnb-711-306/overview/
Direct bolt lug bolt----> http://www.summitracing.com/parts/wld-601-1426/overview/
Me personally would set it up to a 3" bolt. Moroso makes a good priced stud, stronger than the Domain but not the price of ARP's. You just need to know what Knurl size you need and what thread you want.
Moroso bolt---> http://www.summitracing.com/search/brand/moroso/product-line/moroso-wheel-studs?autoview=SKU
Here is a picture of my actual rims on my dart. I have the Moroso 3" studs on a direct bolt style rim. This picture was before I installed the 3" studs but if I had a current photo you would see them stick out about 1/4" or so.
Thanks
found the open ended
shanked lug nuts
http://www.summitracing.com/parts/sum-7555012sstco/overview/
was having a problem finding the 3"
.625" knurl studs
Maybe I had wrong info > .620-.630 knurl
Moroso 46180
say for front disc brakes > .615"
I'll remove one tomorrow to be sure
That's what I used, I have different wheels now, but they still stick out quite a bit.
have the rears taken care of
front disc studs, is what i'm trying to source.
Moroso 46180 @ Summit
