You have to have the app from the printer company. Should be able to find it online, if they provide one.
Install the app, then go through the setup with the instructions that the printer company provides.
Like I said in your other thread, I had issues with setting it up, because the specific driver wasn't on the setup disc.
What printer do you have, make and model.
Brother HL270DW. Downloaded the app but huh?
Thank You Sir. Will mess with it when I get a chance later. Don't know where the hell I came up with that printer #...it is a Brother HL270DW....not that it matters in this conversation.Now you have to go through the process of connectivity. Do you already have the printer set up and connected to a PC? In order for the process to work, it will need to be hard wired to the PC (at least temporarily), then you can follow the steps in the link.
Read first:
http://www.solveyourtech.com/how-to-set-up-wireless-printing-with-the-brother-hl2270dw/
It can test your patience for a bit, but once you have it done, it will work slicker than snot. I like being able to print a picture right from my phone, it does a nice job too.
Just remember, all of this technology is supposed to make our lives easier.
Also, if you have to, you can call Brother tech support and they can walk you through it.
I just went with Google Cloud Print. Once you've got your printers set up in Cloud Print, you can print to them from your Android device.
http://www.google.com/cloudprint/learn/
