[WANTED] A833 leftovers (list of parts I'm missing)
DaveBonds
Garage Trash
Lakewood, CO
I am looking for a couple of hard parts to complete my project 4spd.
Some of these parts I may end up getting from Brewers or elsewhere, but I thought I'd try and give my money to someone here, first.
I'm looking for the following stuff, if you've got it, all or some.
- A/F body 12" tailshaft housing. Iron or aluminum with a good yoke bushing
- Countershaft (non O/D)
- Countershaft spacer
- Front bearing retainer, 4.807 diameter on 4.16" bolt circle (not 5.125" diameter)
- 1st/ 2nd shift fork
- 3rd/ 4th shift fork
- Side cover bolts ('67 up lengths)
- 2nd/ 3rd shift fork
- 1st/ 2nd shift, ball detent lever
- 3rd/ 4th shift, ball detent lever
- Reverse gear, ball detent lever
- Reverse gear
- Reverse gear fork
- Reverse gear shaft
- Reverse detent ball, spring and retainer
- 1st/ 2nd synchronizer hub (3/8" keyways)
- 1st/ 2nd synchronizer shell (3/8" keyways)
- 3rd/ 4th synchronizer shell (3/8" keyways)
- 3/8" synchronizer shift keys (looking for all six)
- Side cover detent balls, pin, sleeve and spring
- Tailshaft vent baffle
- Speedometer gear adjuster/ housing, fork and bolt
If you have any of it, please send me a PM.
Thanks!
Awesome. Anything helps.
There is a lot of parts on ebay right now, but there are a lot of duplicate parts that I just don't need. I'd have to price out the lot against buying some of the parts individually. I just don't want to be in deep with so many parts that it would pay to have another entire transmission.
PM me your email so I can send pics. BTW your FABO message box is full.:eek:ops:
Thanks
I've got a complete tail housing (1968) with main shaft with gears, etc. $90+shipping from 76310
Yowzers! my PM box gets really full, quickly, these days.
Fixed that.
I'll send PMs to both of you.
Thanks!
Date code 1968. 3rd gear shift plate splines have some chipping. Looks like someone in the past got brutal when removing snap ring. Does not effect snap ring locking. I believe most of the gears will clean up.
