[FOR SALE] 340 short block
71produster
clinton twp, MICHIGAN
Rating - 0%
0   0   0
for sale is 340 stroke to 355 cubic inch.3.41 stroker crank,sb chevy 2.1" rod pins ,
diamond gasported pistons,10.5 to 1 compression ratio,carrillo rods, roll master timing chain, comp roller lifters, comp roller cam, water pump, windage tray, mopar flexplate, fluid dampener. less then 200 miles.$3200.00
gross valve lift .715 intake,718 exhaust
duration @.020 tappet lift intake 293,295 exhaust
comp cams part #20-000-9
grinds crs-2228-2229-r108
diamond gasported pistons,10.5 to 1 compression ratio,carrillo rods, roll master timing chain, comp roller lifters, comp roller cam, water pump, windage tray, mopar flexplate, fluid dampener. Less then 200 miles.$3200.00
sold
