Match Race 1966 ~ Valiant 273/235 HP vs. Belvedere 383/270 HP
69 Cuda 440
Legandary Member
Legendary Member
Wilton, Connecticut
Match Race 1966
........................................................................ Shipping Weight
1966 Valiant V-100 {Sedan} ~ 273/235 HP 'Commando' ...... #2814 lbs.
vs.
1966 Belvedere 'II' {Hardtop} ~ 383/270 HP {2-Barrel} ...... #3410 lbs.
Where do we go .........
High-Rev Small Block vs. Low-End Torque Big-Block
273/235 HP
* 235 HP @ 5200 RPM's
* 280 Ft/Lbs. of Torque @ 4000 RPM's
383/270 HP
* 270 HP @ 4400 RPM's
* 390 Ft/Lbs. of Torque @ 2800 RPM's
Transmission options? A well set up 4 speed & good chassis available, I would take the 273 A body combo. 3410 on a B body? Damn ,that's lightweight...
I go with the 273/235 HP... Because I been there.... Done that... (with a 4 speed & 3.55 rear)
My 2 Cents...
Clif of Az.
3, 6, 9, the Goose drinks Wine... a 273 beats a 409...
Match Race 1966
................................................................. Shipping Weight ..... Wt/Hp
1966 Valiant V-100 ~ 273/235 HP 'Commando' .. #2814 lbs. ........... 11.97
vs.
1966 Belvedere 'II' ~ 383/270 HP {2-Barrel} ..... #3410 lbs. ........... 12.62
273/235 HP
383/270 HP
1966 NHRA Classes
* Valiant V-100 ~ 273/235 HP ...... F/S or F/SA = {11.89 to 12.49 Wt/HP}
* Belvedere 'II' ~ 383/270 HP ...... G/S or G/SA = {12.50 to 13.99 Wt/HP}
Match Race
Stock - 273/235 HP vs. Stock - 383/270 HP
4-Speed w/3.91 Gears vs. 4-Speed w/3.91 Gears
The 'Lil' 273 jumps all over the Belvedere 383 {2-Barrel} coming out of the hole.
The high-winding 273 pulls away, and by mid-way down the Track it looks
like it is an '***-whipping'.
But those 273 Commando's 'flattened out' on the big-end.
The 383 gets to chugging at the end of 3rd-Gear, and makes a 'game' run down the
stretch.
Valiant 273 ......... 15.49 @ 86.8 MPH
Belvedere 383 ..... 15.85 @ 87.3 MPH
What I expected,unfortunately. Now when do the "class legal modifications" ,start? My brain tells me more camshaft/better valve springs /whatever is legal on intake tract/full on headers/273 build. 383 combo, the same. The equal work to both, inches will shine,in the long end in class racing.(unless there is a change in NHRA rulings)....
A-Body-Bomber,
I can remember 'way back in the time machine', a 1966 Belvedere 383/270 HP
running in 'K/SA' in 1969 {12.50 to 12.99 Wt/Hp}.
It was a Class Winner every week. Of course, no one could verify if it was
a 'Legal Stocker' or not. As it was never 'protested'.
I'm sure the 'jets' in the BBD were bored out to 'infinity'.
Ran 13.90's @ 100 MPH like 'Clockwork'.
The name of the car.......... 'Clockwork'
Correct,
The 1966 Belvedere 'II' Hardtop was surprisingly not that heavy.
Engine ..................... Shipping Weight ... Curb Weight
* 225 6-Cylinder ............ #3225 lbs. ....... #3371 lbs.
* 318 Poly ..................... #3313 lbs. ....... #3459 lbs.
* 383 {2-Barrel} ............ #3410 lbs. ....... #3556 lbs.
* 383 {4-Barrel} ............ #3436 lbs. ....... #3582 lbs.
* 426 'Street Hemi' ......... #3676 lbs. ....... #3822 lbs.
R-J,
The 1966 > 383/270 {2-Barrel} did better in it's class than the 383/325 HP {4-Barrel}cars did.
Oddly in 1966,
The 4-Speed 383 cars were only available with 3.23 Gears. You could get the 3.55's
in a 727 Automatic 'only'.
Mopar didn't really strike it good with the mid-size 383 in 1966. The {4-Barrel} 383/325 HP was over-rated by a good {35 HP}, and everybody knew it.
They frightened 'no one'.
Shipping Weights
Model ............................... 383/270 HP .. Wt/HP ---- 383/325 HP .... Wt/HP
Belvedere {Sedan} ... .......... #3388 lbs. .. 12.54 ---- #3414 lbs. ...... 10.50
Bevedere 'II' {Hardtop} ....... #3410 lbs. .. 12.63 ---- #3436 lbs. ...... 10.57
Belvedere 'II' {Convertible} .. #3524 lbs. .. 13.05 ---- #3550 lbs. ...... 10.92
Satellite {Hardtop} ................................................ #3518 lbs. ...... 10.82
Satellite {Convertible} ............................................ #3609 lbs. ...... 11.10
{1966} NHRA Class Factor's
* C/S or C/SA ...... 9.50 to 10.59 = Wt/HP
* D/S or D/SA ..... 10.60 to 11.29 = Wt/HP
* E/S or E/SA ...... 11.30 to 11.88 = Wt/HP
* F/S or F/SA ...... 11.89 to 12.49 = Wt/HP
* G/S or G/SA ..... 12.50 to 13.99 = Wt/HP
