[WANTED] 33 tooth speedo gear (i think)
diymirage
HP@idle > hondaHP@redline
michigan
hey guys
I changed out the rear end with a 8 3/4 which has 3.23 gears, and now when I'm doing 45 the speedo claims in doing 70
looks impressive, but rather useless
I run a 245/60-14 tire which the interwebs claims is 25.57 inches tall
If I round up that means I need a 33 tooth speedo gear
anyone have one laying around they want to part with?
Not knowing what gear ratio you had and speedo gear tooth count you had I can't say a 33 is right but if you think so I'll look in my parts stash tomorrow to see if I still have the extra 33 tooth gear I think I have
I didn't realize what I had in there mattered as well
The 7 1/4 had 2.76 gears
I can probably pull the old gear out and check it tomorrow...but I think it is 28
