73Charger318
Member Rt 66 Mopar Club
So I'm wanting to keep my Carter fuel pump with the 5/16th stock outlet and connect it to my new Edelbrock 1406 carb with a 3/8th connection. Edelbrock sells a universal kit, Edelbrock 8135, but the price is nuts for 2 feet of fuel line, a few clamps, some fittings, and a filter I won't even use. What are my options?
I can't find a 5/16" NPT fitting with a 3/8" barb line to screw right into the pump. I can cut the line like I would have to in order to use the Edelbrock kit, buy me a few feet of 3/8" fuel line, but what is the compression fitting I need to take this 5/16" metal fuel line to a 3/8inch rubber line? I'm sure I can do this for less than $40 that this kit costs!
My other option is to put the Edelbrock 1720 fuel pump in with the 3/8th output already at the pump. I just don't think I need this $150 fuel pump for slightly modified 318 motor.
Thanks for any advice. Links to any fittings that would work would be appreciated!
