[FOR SALE] A bunch of misc for sale
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
I'm cleaning up around here and need to sell a lot of parts I have collected. Don't see it ask for it I may have it. I have a bunch of the everyday parts, to many. I spent all day taking parts out of storage and trying to categorize them to list them on different for sale forums. This is a bunch of exterior parts for sale. I will try my best to combine shipping where possible to save on costs. Feel free to make me a counter offer if you feel I'm to high. all items do not include shipping. Thanks
1) A-body front leaf spring hangers 5 in all $10.00 each SOLD two of them.
2) 67-76 Dart trunk hinges $15.00 pair
3) After market 8 3/4 ,8 1/4,Dana 60 shock mount plates $45.00
4) 70-73 Dart rear bumperettes $ 30.00
5) A-body stock shackle $15.00
6) Set of old school long shackles $10.00
7) Wiper arm pivots a-body $20.00 1 left and right
8) 67-72 A-Body V8 centerlink $ 35.00
9) K-member to radiator support brace $20.00
10) A bunch of misc shifter brackets and pieces 68-70 B-body , c-body a-body Column shifter brackets everything for one price $50.00
11) Large ball joint upper control arm, only one, the left side $40.00
12) Pair of disc brake caliper stands 73-76 -body disc. $30.00
13) Pair of lower control arms with sway bar tabs 67-76 A-body $140.00
14) Pair of 67-69 Lower control arms with sway bar tabs will fit to 76 also $120.00
15) pair of 67-72 small ball joints upper control arms $40.00
16) 2 pair of strut rod bars. $30.00 pair
17) 1 1962 B- body strut rod bar $20.00
18) Pair of lower ball joints were in use for a very short time. Car burned $20.00 pair
19) 73-76 manual steering pitman arm used $10.00
20) Left side hood hinge 67-76 A-body $20.00 have others
Hey! Still have your shock plates for the 8.75 rear end? I have a 69 dart I am needing them for. Thanks!
Also need new leafs, and looking for adjustable shackles to give a better stance and more room for my wheels. Are those long shackles that your talking about going to raise the rear end of the car up a little?
Best,
Max
Best,
Max
PM sent
What kind of condition would you say those rear bumper guards for a Dart are in? I can't tell in the photos. Would you say the chrome would clean up? I'm looking for a set to put on a new restoration. The rubber pad condition doesn't matter as much as the chrome. Thanks!
They are not perfect. I would say on a 1-5 scale they are a 3.
View attachment 1714930345 View attachment 1714930345
Do you still have the rear bummer'ets? If so, could you send a few detail pictures? Also, any wiper arm's for a 73 Dart?
I was going to ask you before i shipped them if you wanted me to replace the lower bushings. Done it many times and I have a press. Sorry I should have asked.
Hey There,
I'm looking for a few hard to find parts. Mainly I need a set of headlight bezels for my '66 Dart GT. I would like to find a stock 4 bbl carb in rebuild able condition. I also need front arm rests for the same in black, but could dye them if a different color. Several different models/ years may work.I will have to measure the mounting points to be sure. I will soon be needing trunk and front floor panels too. I don't think anyone reproduces them. If you have any '66 Dart GT parts you can send me a list of what you have. I may need a part that I'm not thinking of right now. Thanks for any reply or advice on where I can source any of these parts. I'm around 1 1/2 hours south of you in Lehigh Acres, just east of Fort Myers.
I
Well I have several different carbs, Edelbrock 600 or 750. Or a factory thermo Quad, I also have a holley 600. Maybe some arm rest if 68 up are the same? I don't have 66 A-body, body parts
I will do some more research on the carbs. I know That Chrysler used a lot of Carter carbs. I'm just not sure what carb was used on my car. If it's a factory carb, that's mainly what I'm looking for. I will also measure the distance between the mounting screws on my arm rests. If the distance is the same, they should OK. Thanks for your reply.
DavidLee ( David Wright)
What was the application for the lower ball joints?
