hi guys
Since I rebuilt my engine I can not get a stable timing mark. Its all over the place. It was rock solid when I ran a hydraulic cam with low spring pressures but now I am running a solid roller cam with bigger spring pressures it moves around at all rpms
[ame="https://www.youtube.com/watch?v=ky4e5Hso7Ro&feature=youtu.be"]Moving timing mark - YouTube[/ame]
I watched a video about a MSd crank trigger and it looks like a great way to get solid stable timing. The only thing is its 3/8 of an inch thick which means it will push out the crank pulley the same amount. I don't want to have to space all my accessories out too so is there a lower profile crank pulley I can use?
cheers Maca
cheers Maca
