dusterbd13
so, in the process of converting my duster from a resto/street/strip car to a pro-touring car, ive come into some interesting problems.
car had subframe connectors installed years ago, and then some very good, and very expensive, pain and body work done.
now there's all sorts of further chassis stiffening products out there, and I know lots more about things. the opportunity to stitch weld the car is long past, so that's off the table. welding the k-frame is on the short list, and the LCA are already boxed. t-bar cross member was welded to the floor pan when I cut it in half for the five speed swap.
Id like to do the radiator support, front fender braces, torque boxes, maybe a monte carlo bar, maybe an x-brace between the subframe connectors.
I know I can do a monte carlo bar, and the x-brace without disturbing paint and body. but what about the rest? maybe the torque boxes, as I don't think they weld to the pinch weld at the lower body.
the core support brace: does it need welded where it would burn the paint past the flange on the frame rails? I can paint the frame rails black to hide it that far, but the horizontal surfaces and inner fenders are very nice and I don't want to hurt them. core support is blacked out behind the grill, so no concerns there.
I believe the inner fender braces are out completely, but I'm not sure.
so, what all can I do without hurting paint or needing to go back to bodyshop hell?
