Pretty difficult to tell from the angle of your picture, but the front end of your car looks pretty high, the wheels appear to be well below the fender openings. If your tires are in good shape there's no need to replace them, you can buy a set of PST 1.03" torsion bars for less money and drop it down in the front with the torsion bar adjusters. Not only will it look better, it will handle better too.
The PST torsion bars don't cost any more than new leaf springs or shorter tires, and raising the back end of the car will reduce handling performance. It looks like there's plenty of room to lower the front end with your current wheels and tires, and the larger torsion bars will keep you from bottoming out the suspension after you lower the ride height.
