PawnCenter72
David and Chelsea rebuild
thank youI would just put some super stock rear leaf springs on it...
I mean in height? Are the XHD 6 leafs also?
XHD's are 6 leaf springs, the standard OE springs were 5 leaf and ~85 lb/in, the XHD's are 6 leaf and ~110 lb/in. I would suspect that the XHD's are fairly similar in height and spring rate to the ESPO 6 leaf springs, but of course being a different manufacturer there are no doubt some differences.
Great. Just wanted to confirm that I am probably going with 6 leaf stock height as I am keeping the 14's on for now so I don't want the 4x4 look.
Ah I don't want to have a harsh ride but need to stiffen up the steering she's like a boat ill look into the XHD's thanks for the inputXHD's are 6 leaf springs, the standard OE springs were 5 leaf and ~85 lb/in, the XHD's are 6 leaf and ~110 lb/in. I would suspect that the XHD's are fairly similar in height and spring rate to the ESPO 6 leaf springs, but of course being a different manufacturer there are no doubt some differences.
And give it a harsh ride, uneven ride height in the back, and worse handling in the process. SS springs are great for hooking up drag racing launches, but for anything else they're not the best choice.
The XHD's will probably add some ride height. The springs that are on your car currently have no doubt sagged, and if they're 5 leaf springs they'll have sagged more than 6 leaf springs would have. So, brand new springs will add to the ride height although some of that will go away as the springs settle in. The 6 leaf springs shouldn't give you a 4x4 ride height with the stock height, but they'll almost certainly add height compared to what you have now.
The wheel rate balance on these cars is pretty car off from the factory. The torsion bars in the front were vastly undersprung, while the springs in the back weren't too far off, especially the XHD's. Going to larger torsion bars in the front will dramatically improve the barge like handling of a stock car, even if the leafs are left alone. Add XHD's and the handling will improve even more. As for the steering, if you have the stock power steering you can modify the steering pump pressure to reduce the amount of "boost" the power steering gives. Mopar action did an article on it for the Saginaw pumps, although you can do it for the federal pumps as well. Still adding spacers but the procedure for the install is different.
http://www.moparaction.com/Tech/beep/PUMP_IT_DOWN-re-v1.4.pdf
If you need to rebuild the front end add Moog 7103 offset UCA bushings, they will allow you do dial in more caster, which also reduces the boat like steering boost feeling. Alignment should be for radial tires too, not using the factory specs.
correctI have a K frame A body correct??
You definitely need new rear springs. Yours are sagging and weak. Get the Super Stock springs and return her to the rake you are looking for.
They are not as bad as you make them out to be...
I've been using SS on my DD for decades with no problems...
I had the same problem on my '69 GTS and temporarily fixed it with 2" shackle extensions but will be removing those and putting on the Super Stock springs in the next couple of months and will get another inch and a half of lift on the rear over where it is now...
It all depends on which Super Stock springs you buy. For the A body, the 3000 lb SS springs are nearly identical to the stock '69 GTS HD springs that it came from the factory with.
Mopar Super Stock Spring Special - Right & Left
I ordered these thank you for the linkIt all depends on which Super Stock springs you buy. For the A body, the 3000 lb SS springs are nearly identical to the stock '69 GTS HD springs that it came from the factory with.
Cool!I ordered these thank you for the link
