[Found!] Big Block aftermarket adjustable rockers
Darrell1
Member
North Fond du Lac, WI
Looking for a set of aftermarket shaft rockers, new or used.
I'm also looking for other parts (roller cam, intake, valley plate, 3600-4200 stall converter, transbrake) so check out my other posts. Maybe you have multiple parts that I need.
Not sure what brand rockers you have in mind.
I have a new set of 1.6 crane ductile irons shelved away.
I'm not particular on the brand as long as it is a good brand. I'm leaning toward aluminum rockers at this point to save as much valvetrain weight as possible but for the right price would consider iron or steel.
