upper control arms
pomonamissel
san jose , ca
have a 64 barracuda with 69 four piston factory brakes and spindles , can i use 73 up uca on this set up ? is it more than upper ball joint issue is there more issues , and is that issue just size of the tapper of the receiver holes in the spindle ?
No, you can't.
hemi71x , is it more than the ball joint ?
There were two used on the A body cars, throughout all the years.
"Small" ball joints were used on the 62-72 A body cars, wether it was drum brakes, or disc brakes.
"Big" ball joints were on the 73-76 A body cars, 6 cylinder 10" drum brakes, or disc brake equipped.
I'm not familiar with the 61 and earlier cars, so i can't comment on ball joints, uppers, or lowers, on those cars.
