Best place to mount a vise?
64DartGTinAZ
Phoenix
Anybody have luck with a mobile vise base (something you can use without the vise moving/wobbling/migrating)?
If so, what's it look like, how's it made, how much does it weigh?
Weld some square stock to a piece of plate and put it in your hitch receiver. Drill a bunch of holes in it for all your stuff(vices, pipe benders, tubing notcher, ect).
Mine is a 1 foot tall chunk of 20ish inch culvert with a forged ford I beam cast into it, offset, with concrete. I welded a piece of 12 inch long C channel to that and welded corresponding nuts to fit the vise. I can stand on the concrete base to offset any movement when torquing on it. The offset gives me leverage to roll it around. I know... Pics. It weighs a lot.
If mounting in truck receiver hitch weld a nut flush into both sides of hitch part. Then you can install a bolt into both sides and tighten to remove any play.
Yote
I have also welded a receiver tube vertically into the top of my heavy but mobile steel welding table . It is also tightened with a bolt to keep it from wiggling. On the other end I mounted in similar fashion a bar to support longer heavy items once in the vise. Both are removable and adjustable for height.
Yote
steel work bench.
