KevinB Well-Known Member Joined Feb 20, 2015 Messages 851 Reaction score 317 Location Austin Jan 10, 2017 #1 Can anyone suggest a kit? The intake is the M1 4barrel dual plane square bore.
xLURKxDOGx "An angel fat, at satan's feast" Joined Dec 27, 2013 Messages 4,361 Reaction score 1,753 Location PHX Jan 10, 2017 #2 Peyote said: Can anyone suggest a kit? The intake is the M1 4barrel dual plane square bore. Click to expand... Where did you get that manifold, I was looking everywhere for one. Jake
KevinB Well-Known Member Joined Feb 20, 2015 Messages 851 Reaction score 317 Location Austin Jan 10, 2017 #3 xLURKxDOGx said: Where did you get that manifold, I was looking everywhere for one. Jake Click to expand... I bought it from the link below, and I bought the only one they had left. I believe it's discontinued Aluminum Dual Plane Intake 4-bbl Carb [P5007381ab] - $344.85 : CHICAGO CONNECTION, Your High Performance Parts & Accessory Shop
TrailBeast AKA Mopars4us on Youtube Joined Mar 11, 2011 Messages 22,522 Reaction score 12,111 Location Arizona Jan 10, 2017 #4 13 bucks or so from Summit. You probably couldn't get them all with washers from a hardware store for that. https://www.summitracing.com/search...2l-318/engine-family/mopar-small-block-magnum
Lelo Dart * Joined Oct 10, 2012 Messages 1,518 Reaction score 470 Location Knob Noster MO. Jan 10, 2017 #5 https://www.summitracing.com/parts/dcc-4876772
sireland67 FABO Gold Member FABO Gold Member Joined Oct 27, 2010 Messages 10,982 Reaction score 6,799 Location WV Jan 10, 2017 #6 I bought mine from McMaster-Carr. I just bought stainless bolts and washers. I can measure one of them tomorrow. Congrats on getting the intake, I bought the second one they had left.
sireland67 FABO Gold Member FABO Gold Member Joined Oct 27, 2010 Messages 10,982 Reaction score 6,799 Location WV Jan 10, 2017 #7 They are pretty nice, it makes good power right from idle. It does take a small thermostat.
sireland67 FABO Gold Member FABO Gold Member Joined Oct 27, 2010 Messages 10,982 Reaction score 6,799 Location WV Jan 10, 2017 #8 Also, I drilled and tapped the center 1/8 NPT temp sensor hole to 3/8 npt to run a mechanical gauge. Along with the stock gauge. I think this was on over site by mopar.
skizzo Fubar Emeritus II Joined Jul 22, 2015 Messages 153 Reaction score 22 Location Castle Rock, CO. Jan 19, 2017 #9 3/8" x1 1/4" socket heads are nice for access. I just used my old LA arp's. If you have a TCS near you you can get grade 5's pert cheap by the lb.
sireland67 FABO Gold Member FABO Gold Member Joined Oct 27, 2010 Messages 10,982 Reaction score 6,799 Location WV Jan 19, 2017 #10 What heads are you running? I have eldebrocks on mine and the bolt size is 5/16-18 x 2"
