Show off your small block.
My peewee 340
Looks good! Clean look. I'm really leaning towards painting my Edelbrock light blue for a stock look.
Thanks! I was shooting for a stock look, even if the motor really isn't stock. Now that I am working on going EFI, don't think I will be able to maintain that look.
Does the hood close on that 6 Pack without a scoop? I was thinking on doing that to my 69 Barracuda, but I want the stock hood to close.
Yes. However I had to trim the hood braces and the back of the hood brace. I also had to trim the air filter. If I used mopars air cleaner I would not have to trim anything. But I used a Mr. Norms air cleaner. Yes it's a stock hood.
lol sorry my thumb must have hit the button when scrolling..opps. yes all very nice!
Last winters project.... the low dollar 318. Getting it going last spring...
I want to paint it, but it's a Leanna powdercoat masterpiece. Seems sacrilege to put paint on it. I have no excuse for the water pump but laziness..
I don't recognize that motor Ben. I don't believe it had anything to do with me, but I like the way you think. LOL!!!
Building two of these 408 Stroker 5.9 Magnums with Enginequest heads and Hughes Hyd Roller cams for my 27' Magnum Marine boat
And collecting parts for a Poly 318 to go into my 21 Dodge Lakes speedster
Just looked at a Hot Rod 318 poly build..stroked to 402 it made 547hp and 566 ft.lbs​
Yeah the Poly blocks can be bored over .100 and still have good wall thickness, along with a stroker crank you can build a big inch motor, and the heads are decent to work with. THis one is going to be mild with the 3 Holley 94s, some lakes headers, a mild cam and some mild porting on the heads with 9 to 1 compression
here is a pair of 318's, an LA and a Magnum I have sitting in the storage shed.... never know :D
