69swinger340391
I have a 69 Dart Swinger 340 with original exhaust manifolds. Could someone post a picture of the correct position to mount the 90 degree oil filter adapter?
Thanks
Thanks
Sanguine said:you don't want to use the adapter unless absolutely necessary, and it shouldn't be with you stock manifolds, use the short filter
mullinax95 said:I am wondering what is the purpose of the 90 degree adapter? I was thinking maybe later getting one so I can avoid the mess that happens when I unscrew the filter straight from the block. At least the 90 degree wouldn't make such a mess with oil running down the filter.
340mopar said:If you want even more room use a 2.2 or 2.5 filter like off of a Shadow/Omni/Spirit etc. basically and 2.2 or 2.5 4 cylinder. I use them on my cars and it is a ton more room.
Chuck
littleman66 said:do you change your oil/filter more offten now
djwhog said:So i went with a remote mount and it also helped me to add 2 qts to my 6 qt pan.
Sanguine said:every 90 degree turn the oil makes it cuts the flow down a significant amount
I use a short filter and i drilled an extra 4 holes in the plate, so it has 8 rather than 4
hey adam , maybe it is just me but isn't the heat from the header pipes going to be kind close to the filter? looks like it would cook the filter like that. i would think a 90* adapter would help you at least move it back away from some of that heat from those pipes. just my 2 cents....AdamR said:Im just using a short filter this time.. My last 340 had the 90* adapter on it and I never had a problem with it.
Wow! Raised from the dead thread.
Nice to see someone reading this far back.
Anybody have a diagram/pictures of how the stock 90* goes together?
Just figured it would be good to post!
It points rearward with a slight downward angle of about 5 - 10 degrees...
Here's two engines that had it from the factory...
Here you go:
