Ive decided to see about discs on my 67 cuda. Drums now. I like my sbp rallys so I'll probably keep em, but go wider on the rear. Donor vehicles are not around here. What's my next best way to do this and cheapest if possible?
You're in Indiana right? There's plenty of donor vehicles aroundThanks all!
Stainless Steel Brakes sells a drum to disc conversion for the SBP. They use the KH OEM style 4 piston caliper. 4 Piston Front Kits
Maybe where you are but up here there's none I've found.You're in Indiana right? There's plenty of donor vehicles around
Nah, there's some yards around that area. You may have to drive out into the country side to find some, Muncie is only 60-90 minutes from me and I know there's a yard north of shelbyville that has a few a bodiesMaybe where you are but up here there's none I've found.
I have been eyeballing this kit, because it is a complete package other than the master.Ive decided to see about discs on my 67 cuda. Drums now. I like my sbp rallys so I'll probably keep em, but go wider on the rear. Donor vehicles are not around here. What's my next best way to do this and cheapest if possible?
Muncie has none. A couple of old chryslers. They are expensive and picky about parts on em. I'm sticking with sbp cause i,like the rallys that's on it. Rather have cop wheels but don't have the cash to buy rear end, tires wheels bbp discs etc.Nah, there's some yards around that area. You may have to drive out into the country side to find some, Muncie is only 60-90 minutes from me and I know there's a yard north of shelbyville that has a few a bodies
Thanks. Nice kit and price.I have been eyeballing this kit, because it is a complete package other than the master.
DBK6272A-40 - 1962-1972 Mopar A Body Small Bolt Pattern Standard Disc Brake Conversion Kit
I hear ya man. But I'll let you know the next time I head out to one, you're welcome to tag along, probably be may sometimeMuncie has none. A couple of old chryslers. They are expensive and picky about parts on em. I'm sticking with sbp cause i,like the rallys that's on it. Rather have cop wheels but don't have the cash to buy rear end, tires wheels bbp discs etc.
What are you swapping the rear too?I'd like to go to cop wheels,rings,and caps,but can't afford to. I'm swapping the rear. Mosier supplies sbp alloy axles.
Dunno, I have a 9" ford and a Dana 60. Both will need to be narrowed, 800 to 1000 at Mosier. There an hour from me and they did a couple of rears for me. Cost is the same from them, bbp or small. It's the cost of everything else. Thanks for the offer to tag along.What are you swapping the rear too?
I have the dodge 14" rallys on it now. They may not clear either. Thanks.ssbc conversion from 10'' drums to there disc set up widens the track of the front . and 14'' steel rims would not go over the alloy alum calipers , mag 14x7 us indy's just clear , but the weight must be placed in the right place . did a 71 duster , found out the hard way on tires , had to buy some smaller ones to get them to clear the set up and glass fenders . rotor came in 4'' n 4.5'' bc View attachment 1715038363
FYI, doing the factory swap will also widen it. The factory disc were about an inch wider or so track width over the drumsssbc conversion from 10'' drums to there disc set up widens the track of the front . and 14'' steel rims would not go over the alloy alum calipers , mag 14x7 us indy's just clear , but the weight must be placed in the right place . did a 71 duster , found out the hard way on tires , had to buy some smaller ones to get them to clear the set up and glass fenders . rotor came in 4'' n 4.5'' bc View attachment 1715038363
Sounds like I otta stay with a sbp disc kit... But maybe not ssbc..?FYI, doing the factory swap will also widen it. The factory disc were about an inch wider or so track width over the drums
Thanks!I suppose
1965-72 Dodge, Plymouth "A" body, with 10" drums Wheel Kit
is the most affordable route to SPB front disc brakes. Since that ( and most others ) retain and rely on the OEM hubs and spindles, 4 new bearings and 2 seals should ad to the total cost.
They do recommend longer lug studs. The OEM left hand lug studs are difficult enough to find so hunting longer left hand studs is probably a wasted effort.
If you'll switch to longer right hand studs on both fronts, 5 more OEM right hand studs at left rear gets right hand all the way around. Just another small addition to the total.
