moparmat2000
I am putting M body discs on my kids 69 barracuda. I know i have to use the 73 up disc brake lower and upper ball joints to use these brakes. I am using the 69 barracuda K frame and center link. According to rockauto, the adjustor sleeves are the same PN# from 69 up thru 76.
Heres my question. Rockauto shows different part numbers for the 69 tie rod ends and the 73 up tie rod ends. Do i just order the outer tie rod ends for the 73 up disc brake setup, and order the inner tie rod ends for the 69 barracuda?
