ScampMike
Despicable Damn Yankee
do you have wifi now?But my testers and cars go from 1941 to 74! I am so confused! Actually looked into it would have to run another line out there.
no ****? or NO ****!! or oh ****!!!Pink pants lady cited this morning still has the same outfit on.
No you didn't!who needs TP anyway...
They can have issues with the injector pump if you don't run a good lube in the fuel. I have a 2002 I run power service with every fill up, no problems with mine 140k on mine. And they need a good lift pump to help cool the injector pump.do any of you know what to look out for when buying a dodge ram diesel
its a 2002 with 120k miles and looks good but i dont know the common problems with them if any??
yep, raptor 150 or airdog if you got the money for it.They can have issues with the injector pump if you don't run a good lube in the fuel. I have a 2002 I run power service with every fill up, no problems with mine 140k on mine. And they need a good lift pump to help cool the injector pump.
Yes it is.or - it must be nice to be on permanent vacation
Yes it is..... Going on 18 years now............or - it must be nice to be on permanent vacation
I had 260,000 on my na 6.5 GM in my tool truck. A quart of atf every other tank or so works well to keep the old mechanical pumps and injectors lubed and running smooth.They can have issues with the injector pump if you don't run a good lube in the fuel. I have a 2002 I run power service with every fill up, no problems with mine 140k on mine. And they need a good lift pump to help cool the injector pump.
I've been pretty fuckin' high a few times - and that has never happened....What does it take to get that low? ******?
what???No you didn't!
I've been pretty fuckin' high a few times - and that has never happened when I was young!
Even if I run out of TP imma wipe my *** with one of my socks or both......what???
she just cut out all the paper work - went right to processing..Even if I run out of TP imma wipe my *** with one of my socks or both......
May be she was doing "schrooms". They make your digestive sysyem go to sleep. Lol ( or so I've heard)I've been pretty fuckin' high a few times - and that has never happened....
