[WANTED] 1970 Dart front fender extensions, HELP!
fnabody
In the process of restoring my 1970 Dart Swinger 340 and i'm in desperate need of a pair of fiberglass 1970 only front fender extensions with NO broken studs. I don't want to beg, but can anyone help me out here? Thanks in advance!
I had a set for sale this weekend and will have to go through the bins to locate - raining now so rain suppose to stop on Friday
your inbox is full.
I thought you should know that there are two different style fiberglass. Shallow and deep. You will need the deep style for a 1970 grille. If you are using the eyebrow chrome on the extensions for a 1970 they will not fit the shallow style. The shallow style come on 1972's but they do find there way onto other cars over the years and some sellers may not know the difference. Just some info you should know Steve
Ok just some info
1970 fiberglass with double ended studs
1971 potmetal with molded in studs
Both 1970-1 take the deep eyebrows
1972 potmetal with removable threaded rod - SHORT eyebrows
You can find some fiberglass on early 1971 but generally each year is different
