[FOR SALE] Manual steering box, Floor shift Column, Bell housing, 4 speed hump, disc brakes
dano
Evil Handy Man
Gresham, Oregon
All prices are without shipping. I do take PayPal. Pics on request, I plan to upload some soon.
Manual Steering box standard ratio, pitman arm and bolts $100
Power steering shaft and coupler for steering column. Pins are not sheared $50
11-3/4" disk brake conversion, ready to bolt on. Includes calipers, lines, rotors, good low mile Timken bearings, Pin type caliper brackets, Pins. All you need are A-Body Disc brake spindles. $250
1968 one year only LA cast Iron bell housing for 10.5" clutch, part number 2843887. Is missing pivot bracket for throw out arm. $150.
4 Speed A-Body floor hump, out of my 69 GTS, no or very little rust. SOLD
Polished "Holley" script Aluminum valve covers for LA engine. Polishing needs buffed but in nice shape. Not painted ones that were polished, these came from Holley polished. $110
Pics of disc brske conversion parts
Includes calipers w/good pads, brackets w/factory bolts, slider pins, rotors with bearing and seals. Lines may or may not work out depending on mounting, I had these mounted forward. Basically add spindles and shields. All worked when removed for a Dr Diff 13" brake kits. used very little as car has been mostly sitting for restoration. Sorry for the crappy pic, this is when they came off, they are boxed not and stored indoors.
