[WANTED] 1966 Emergency Flasher switch trim
RogerK
Roger Kizer
Colchester,CT
I'm looking for the chrome trim that says "Flasher" that mounts with the switch. If you have a "Rear Air" trim I'll take that too. Photo for description.
I have a 68 A body flasher switch.
IIRC it looks very similar.
If I can find it....
Tell us about the "rear air"...
“Rear Air” in a nutshell refers to the rear window defroster which takes passenger compartment air in through a vent on the package tray and blows it through a defroster-style hose to the output vent also on the package tray against the rear window to clear it of whatever.
Thanks.
I guess the changed that to "RR Defog" after 1970, at least.
I was pretty sure it didn't mean "rear A/C".
I just got through inventorying some of the small parts I will be using on my 47 to upgrade it a bit - the mid 60’s FASTEN SEAT BELT and BRAKE warning lights
and will be using the middle 3 chrome bezels with the appropriate switches and harnesses as well.
I do have an extra FLASHER bezel/switch
but the only other REAR AIR I have is the black one next to the one I’ll keep.
If you are interested in the extra chrome FLASHER bezel and/or the black REAR AIR bezel/switch, drop me a PM.
