I have a new set of Com Cams 955-16 valve springs. I bought these for a solid roller cam but decided to use a different camshaft. Specs are as follows:
Outside Diameter of Outer Spring (in): 1.550 in.
Coil Bind Height (in): 1.230 in.
Damper Spring Included: No
Spring Rate (lbs/in): 526 lbs./in.
Inside Diameter of Outer Spring (in): 1.135 in.
Inside Diameter of Inner Spring (in): 0.812 in.
Price is $250 shipped in the lower 48 states.
