erafuse
Have a 1973 Dart Swinger. What is the lowest gears you can get for the rear end? Looking to lower the rpms at highway speed.
Think there are 323s in there now. I new I need a lower number just had the wording wrong. Do you think 278s would lower the rpm much?you want higher gears not lower I think there is a 2.45-1 or a 2.78 -1 or a 3.23-1 what is in there now .?
Okay thanks.Be carfull, some 8 1/4 rear ends will not go very high , I have a 73 rearend out of a duster that could not go much lower then 2:45, I put 2:78 in it. something todo with the case and pinion location
