Bills70
My fuel and temp gage are not working! I looked at wiring diagram in service manual and it appears that there is a "voltage limiter" that is in that circuit for both gage's! could that be bad and causing my problem, if so, how do I check it if it is? if the limiter is bad will I still have power to the tank? I will check to make sure I have ground at the tank! Also, my tank and sending unit are new, so I am pretty sure it is not the sending unit! Also, if my "Limiter" is bad, does anyone know where I can buy one?
