didn't know 33 made it that far westMolson will just have to wait until I get to the other market. For this evening it Rolling Rock
Yes you did.It’s a good thing that it’s going to be cloudy and rainy for the next 2 days...I got more sun today than I thought.
You look like ya stuck your head in too far cooking the crabs.It’s a good thing that it’s going to be cloudy and rainy for the next 2 days...I got more sun today than I thought.
I assume it has a carburetor. If so, it is likely the carb/spacer gasket. Seems to be a common problem.Its a ford 460 1991 in an F-250
anyone know of any common vacuum leak problems and where to look ??
If not, it might be the fuel pump regulator vacuum line (but I think these were on later models).
Check the fuel pump regulator vacuum line.Its an EFI ...I sprayed the intake and upper plenum with carb cleaner looking for the leak but I didn't find anything there but huge problem is I didn't hear the vacuum leak when it was running in idle ... the leak comes and goes and I cant predict when it will show up
Is fuel injected.Its a ford 460 1991 in an F-250
The more I am working on fords, the more I am starting to like them.
I can see why RRR likes them. They are cheap and easy to find (like Mr. Ben)
I may go ford one day ......(is she joking?, who knows)
Is fuel injected.
Dont recall what it has for an intake/plenum but it wouldnt suprise me if its leaking.
Also egr could be an issue.
Woukd need a better description of the trouble,rich/lean/hot/cold,you know give me something to think about.
When is the toast done?
I actually suspected the brake booster because I just changed the master cylinder ....(whole other story) but the brakes work great now.Egr valve. Or brake booster.
Egr could have a lump of carbon floating around in it.
probably Sunday morningWhen is the toast done?
Vacuum modulator for transmission or the hose/line going to it?Its a ford 460 1991 in an F-250
If you think there is a vacuum leak remove the vacuum line and see if the leak goes away.I actually suspected the brake booster because I just changed the master cylinder ....(whole other story) but the brakes work great now.
How would I test the brake booster ?
My son and I are building this 51 ford with a 460 in it,when it runs without a vacuum leak with full power, I am actually starting to like a good big block Ford.
I can see that engine in a smaller car like a maverick or a fox body format.....talk about a rush.
Engine definitely has some power, and I am reading up that it is a kin motor to the 429. I am in discovery mode again and enjoying every minute of it
I am about to start pulling my hair out.
I am wrestling with a vacuum leak problem.
Its an intermitten vacuum leak and when it leaks, the engine bogs out and doesn't shift properly and yet when it doesn't leak , there is a ton of power.
I have used carb cleaner to try to chase it, I have gone over vacuum routing diagrams, even isolated vacuum circuits and still cant find it.
It only seems to happen on the road is the real problem. I would ask FABO experts but its a non mopar vehicle ....AGGHHHH
