Hi its a 3 speed automatic .If it is a factory 4 gear it is bottom of the dash just below and to the right of the ign. key
Hi ok so the switch mounts on the base of the column with two screws . tylerIf it is a column shift it plugs into the switch at the base of the column, if it is a console shift it plugs into the console harness.
Alan
