MoparMan65
For sale all balanced internally with everything needed to build 408 stroker. All forged internals. Also have camshaft that will come with lifters and timing chain. All parts have very little run time and crank, balancer, flywheel, lifters, timing set, and camshaft were purchased new. Only selling because going a different route. All items will be shipped on buyers dime.
Rotating assembly: $2200obo
4" Scat 4340 internal balanced
Eagle H beam Rods with 2000ARP bolts
Probe flat top pistons forged
Neutral balanced fly wheel sfi approved
Neutral blanacer Trick Flow sfi approved
Camshaft: $500obo
Hughes Hyd roller camshaft
Billet timing gears with chain double roller
Rhodes v-max lifters
Harden oil pump drive gear
Engine Block: $400obo
Clearanced for stroker
4.030 bore for .030 pistons
Main studs with line bore
All machine work performed by local shop Oakley Motorsports
Ready for assembly
Can ship by Fastenal
Location Philpot, KY 42366
Also have various pulleys covers and also a kevco center sump oil pan with pickup ($150). As well as various factory 360 engine parts rods camshafts pistons and crank from the build left over if anyone is interested in that. PM for inquires. All parts are ready to be shipped ASAP
Camshaft: $500obo
Ready for assembly
