1967 notch barracuda door window assembly
63spf
DODGE'S ARE KOOL BUT PLYMOUTH'S RULE !
Kona , Hawaii
Aloha, im looking for a diagram or book or somthing to help me assemble my Cuda doors. Everything was striped b4 i bought the car and i am trying to find all the pieces and do the job myself. My bad, never done this b4 but cant be that hard. Any help , would be great. Mahalo ftom the Big Island of Hawaii,C
I can take some pictures for you. I have a 67 door that I am working on that has the panel off. Maybe I can draw something out if nobody else has one. Have you checked the fsm? I’ll try to work on that today for you.
I need the window guides and tracks , get funny looking double nuts that hold the A pillar or ash window assembly or something .Plus other window brace at bottom of door. I just Don't know ? Any Help would be OH SO SWEET !!!
So the wing window attaches at four places in the door. The yellow is the double nut. That goes to the front of the door behind a plug that you can see from the outside of the door. The blue slides over the peg that is also accessible behind a plug in the bottom of the door. Hope that helps. When I get a little more time I’ll see if I can get some more pics of the rear window channel.
Never thought it could be that hard to reASSemble somthing you did not take apart. OMG,
Never thought it coild be that hard to reASSemble somthing you did not take apart. OMG,
Not only that. It can be hard to reassemble something you took apart yourself if your memory isn't very good or you did not document it.
Bump, thanks for the thanks Mattax! knew there were good 67 reference pics somewhere.
Thank you @67notch for the great details!
Some dont know how much of a pain or the time it takes to post good pics with description.
Thank you!
Chris, I'm doing the same thing with mine now. I have some extra stuff , like door glass and the chrome frames for the vent windows and track ect. When I get mine all done up I can let you know what I have left.
