[SOLD] 69 340 complete motor
superbeesrt8
mi
Rating - 85.7%
5   1   1
69 340 complete engine X heads 2000 plus shipping
Put @Eddie348 in line. We can come pick it up if you're close enough.... Where in Michigan are you located???
What all is included in "complete" motor??? Please post pics of what's included in the sale...
I will have to go get some more pictures of the motor but it’s complete intake water pump balancer still on the motor if it’s standard bore I’m not sure because the motor is all together still
What would you like to see of the motor I could pull one head to ck the bore but I’m not going to pull the complete motor apart
Really just a look at the bores, pic of the Heads valve side and Taking the Sump off to see the Crank's not the end of the world.
Could be seriously damaged, could be mint. Id take a punt at $600 as is, but not $2000.
Buy a bore scope, $35 from Amazon.
It uses your camera as the screen.
You can take pictures and video with the camera.
Easy way to look at the cylinders.
I have one, well handy. Just pull all the plugs for easy rotation and look in each bore, rotate for the next. But still, not the best for selling. Wont tell you much about anything else or what size the bore is.
I’ll pull one head to look at the bore size and look at the heads I’ll be out of town till next Wednesday then I’ll post more pictures of the inside with the bore size
