87mm Cold air intake
Sublime one
72 Demon
Northwest Arkansas Blair Creek Training Center
So I just swapped to a 87mm throttle body rendering my CAI that I so laboriously cut and mitered and welded by hand useless. It is on a 6.1 gen 3. My question is do any of you Hemi swap folks know of a good 87 mm CAI or am I back to welding a new one up? As many of the 87s they sell somebody has to make a CAI for it? Any clues?
You are wasting your time with a larger TB on a stock 6.1L engine. The stock TB already pulls way more than the engine uses and a larger TB does nothing but take your cash.
Ask me how I know...
Injen cold air intakes are great, had one on my 06 SRT8. Could feel the difference, even before I changed tunes on the diablo for the cai one.
The 6.1 is not ending up stock in spite of my best intentions to do so. I had to purchase a new throttle body anyway as I also changed throttle control configuration. Figured might as well do the 87 so new cam can breathe! That's how I ended up needing the CAI.
Well then, the easiest thing to do and probably best for your application is to fabricate your own.
Everything you need can be found here...
Air Intake Components
