What to expect out of mild build 360
NormalPcGamer
Member
Winnipeg
Hey, I'm looking for other people with a similar build as me so I can sorta gauge how the engine is running.
Car is a 1975 Plymouth Valiant
1978 LA 360 .030 over, flat top pistons, unknown compression ratio
U cast heads 2.02" int 1.60" exh
Comp XE268 cam specs
Edelbrock 750 carb #1407 set up to #9 on the Edelbrock calibration kit
Vac advance (ported vac source) distributor 19 deg at idle 38 total at about 2750
Hooker headers to dual exhaust
NGK RN14YC spark plugs
other things
3.23 suregrip in the 8 3/4
1973 904 transmission
25" tall tire
I don't know what I should be expecting out of this setup. I've owned this car for about 3 years (2 of that with the stock 318) but now I've swapped this engine in and its hard to tell if its actually running how it should be. I've never driven or really even been a passenger in any other car around this era (I'm only 21) and my other car couldn't be more of an opposite comparison (2013 Focus ST). My dad and I have been chipping away at everything that's been breaking on this car over the last 6 months or so but now its starting to run good enough where I can start fine tuning the carb and timing.
I'm trying to absorb as much information as I can so if you've got a similar set up, post as much information as you can, as in, carb size and jets/metering rod settings, timing, HP/TQ numbers, 1/4 mile times, videos of the car driving, tuning tips/tricks, anything I can use to compare my car with so I can get it running as best as I can.
Thanks!
Should run very low 13, and with no wheel spin and tuned proper, maybe a high 12 in the 1/4 mile.
First welcome to the team..:D..
Just so you know from my experience if it's a well-tuned 360 4 barrel with headers and a decent cam, 25 inch tires and 323 gears... It should start idle and run smooth and have no hesitations, coughs, or giddy-ups...
In other words from a dead stop in drive you should be able to stomp it to the floor and without hesitation it should burn the tires seriously... :thumbsup:
Run a compression test and post up the numbers. We can come real close to telling you what it should make.
Are you planning to take it out to the track any time soon?
I'm gonna try to this year if I can find a trailer to take the car, closest track is about an hour and half away.
Yeah I finally took the carb apart to rejet it last weekend and it was set up as lean as it could be. I have the tuning kit for it so I set it back to stock settings and that was the first thing that completely changed how the car drives, and after a little more adjusting I was able to get rid of the off idle stumble I've heard about the Edelbrocks. although I haven't driven it that much since because I've been having some overheating issues, still running the stock 22" rad.
sounds like you're doing the right thing for now just driving it and letting the little things pop up and fix them as they come along. I would be getting the overheating problem fixed...
It could be anything from a pluged thermostat to a bad tune...
That's low. Was the camshaft degreed? I'm guessing it was installed dot to dot. You could add a lot to that if you went in and degreed and advanced it some.
Yeah its dot to dot. I think the engine could take more timing because we can't get it to ping but instead it will start to stumble, like its starts to fire on the next cylinder. is there any way I can get more timing in it without taking the front cover and degreeing the cam?
The overheating problem has been coming back and biting me all year, I've replaced the coolant hoses, added a electric pusher fan, put the shroud back on and even bought a 6 blade fan to replace the stock 4 blade from the 318 and nothing has helped, it would be running at 210-230 after 20 mins on the highway. I've got a 3 core aluminum rad and 16" fan coming on Monday that should fix all those problems though
The only thing I can think of to add to that is making sure your bottom hose isn't collapsing under RPM..
You can get more ignition timing. But it needs more camshaft timing. Don't let it intimidate you. It's an easy job with a lot to be benefitted from. You could be talking about a 50 HP change with both camshaft and ignition timing.
Yeah I may attempt to do that when winter comes along, the only reason I'm concerned is because when my dad and I were rebuilding the engine we accidentally stripped the threads for the balancer bolt so we just loctited it in there with whatever threads were left. But if its gonna give me some good gains it might be worth it to try
They make these new things. Maybe you've heard of them. Heli Coils. I think they've been around since the 1930s. LOL At any rate, that will fix your problem if it's the crank threads that are messed up. It could be the bolt itself, which is an easy fix. Either way, it's very repairable, so don't let that slow you down.
3.23 gears and stock convertor it isnt going to run anywhere close to real low 13’s. Maybe real high 13’s if i had to guess.
Back in 1972 i had a 69 340 swinger. Headers and 3.55 gears. Ran 14.23
This should run better than that no doubt. I will say 13.70’s- 13.80’s
This all assumes he has a stock convertor
I just ran 13.5's with 2.76 gears, stock converter, AND a stock 360. He has more bore, more cam, more compression, better heads. I'm sure low 13's won't be a problem, maybe he'll go high 12's.
What is your combo and car weight? Impressive
Car weighs over 3200 lbs with 1/4 tank of gas, no spare, without driver. Stock smog heads, stock dished pistons, stock crank, stock rods, how about I say stock long block with a .427 lift / 204@050 cam (less than a factory 360 4bbl). 750 Holley DP on a eddy intake. Headers/duals out the back.
Very impressive. Hard to believe that could run better than a 340 with x heads and more gear.
Is your home track like straight downhill....?
