Name these parts??
4spdragtop
Ontario Parts Unknown
Not quite sure what these are, both were in a box of parts in my 69 cuda 4spd vert but may not be related?? Piece in my hand is "molded fiber board". With 4 mounting clips.
Thanks
Steve
I can't go outside to take a pic because I am in bed with an injury.
Hopefully this makes sense..... it's inside the wheel well
I stared thinking, I don't think the striker shim is A body. I have those laying around off my B bodies.
I don't think those are used on A's
This is a B body door striker. I think E body used the same one as well. You can see two shims behind the striker.
I had to have someone go out and take a pic because no way am I going to draw that and make sense LOL.
E body used a Nader pin like the 67 up A body. The B body went to the Nader pin in 1971 after the redesign.
Then it might be C body I saw the same one as the B body.
I have the alphabet soup here A,B,C,E and F body
What the heck happened to make you be in bed recovering.
You ok?
If you don't want to talk about it I understand.
