yellow rose
Overnight Sensation
I have a matched pair of closed chamber heads and one open chamber head for sale.
The closed chamber heads have some issues. One head has a small crack from the spark plug to the intake seat. The other issue is the intake guide bosses have fractured on one cylinder and fallen off, and the others are starting to crack. I would push out the guides and machine off the front of the guides. Also, if you look at the pictures very close, you can see on the pair of closed chamber heads someone has drilled and tapped to pull coolant from between the exhaust ports on the intake side of the head. It's in the big, gaping hole where the heat crossover should be. You can either use it or just plug it off.
The open chamber head is a single.
$650.00 OBO for the pair of closed chamber heads plus actual shipping from Selah Washington
$400.00 OBO for the open chamber single plus actual shipping from Selah Washington.
