[FOR SALE] Speedo gears
oldkimmer
Kindersley, Saskatchewan,
25-31. $20.00 usd each plus shipping. Thanks. Kim
do you know what gear i need for a 78 chrysler cordoba that had a 904 automatic transmission bolted to 360 ci /v8
Do u know ur gear ratio and tire size. How much is it out. How many teeth does urs have. There is charts on this forum or on the net to help u also. Kim
my rear differential is a 8 3/4 with 3.55 gears and the transmission never came with 1 and i running 245/ 65r 15 on rear. where do i find this chart you speak of i was going to use gear from my 65 barracuda 904 trans that had a /6
You can't use a 65 gear they are totally different . you need 66 and up
i am running 27 inch tire so it looks like i need 34 spline gear teeth and housing that holds it and is held in place by clamp
O.K.
From what I read, I need "38" gears (4.10 gears 28 tire..27.75 to be exact)
Can you help ?
Thanks.
MAPS
