[WANTED] 4 speed output shaft
Ironmike
Western Pa
Looking for a very good output shaft from B or E body. Want to go Gear Vendors Overdrive and an A body shaft will not work. No spline twist or chips need apply.
Thanks!
Your in box is full. I have 2 that I can sell. I will swap a B for an A. Please contact me if interested.
i have a out put shaft from a 3 + od ox and put it on the alumin833 what length do you need? this one is longer than the one for the Dart... i just swapped the tail shafts took the A body shaft off the 4 speed box and put in on the aluminunum 3 + od Box.. so still have the complete longer 4 speed tail shaft complete and together.
Hi, I dont want to Hi jack this thread but since you have two B/E body output shafts I am looking for a good one as well, for the same reason,.. PM me if available.
Appreciated
Ground hog day, marksmopar1, Your Inbox is Full as well. Send me a conversation when you get it cleaned up!
Hi, this is the shaft A Body 833. Sorry I could not load the pictures on the message board, Let me know what you think... or if you want any other pictures? Pictures of the B body shaft, I am interested, Thanks!
