67 Barracuda door latch assembly
Dk1985
Member
Akron
Hello all. I’m putting the door hardware in my 67 barracuda. The original latches are pretty nasty. Will the 68 latches fit and function correctly? I have seen 68 Reproduction latches. Not sure what the difference is. Also looking to buy a 67 driver door rear window track in good condition. Thank you in advance
I should have some door latches from a 68 barracuda.
if needed let me know and I’ll take a look
Also, depending on the level of "nastiness" you can soak them in Evaporust and they clean up pretty darned good.
I will give that evaporust a try. Would be nice to save a few bucks. Let me know if you have the glass track. Thank you
I usually have successs with cleaning them well and then bead blasting them. Lube them generously and be sure everything works as it should. Good luck.
