Yes, 63-66, including the convertible, are the same.Are all Early A Dart windshields the same? I have a 64 Dart convertible with a beat windshield.
??? dot matrix tint? tint is in the glass(iron ore to be exact) the Shaded part on top of the windshield is in the Vinyl that is sandwiched in between the glass and then put in a vacuum chamber or "autoclave" to heat and both the 2 layers of glass and 1 inner layer vinyl together. what exactly is the dot matrix look coming from ? (I worked 30 years at the McGraw Glass plant making those windshields.)Look at Laysons also. They are the only place I found that actually has real tinted glass instead of that dot matrix tint.
